rev-tech motorworks rt 4wd project in the making!!
this is my 1989 rt4wd i picked up from Seattle WA. when i got it, it was all stock with a big dent in the driver rear quarter panel that was not mention when i agree to buy the car. but it has no rust!! so here is the start of my big project. goal 400awhp boosted. :shock:
Cars looking great Hai. Shoiuld have shaved the rear wiper and hood squirters/emblem since you had the razor out
BTW, didja find that little trim piece that goes behind the rear door that you were asking me for the other day? Cause if you didnt, pretty sure bam bam has one of those too.
didnt even notice the plates... welcome... the idaho wagon squad is like herpes; we're everywhere and everyone has one... lol
as far as the rear sway bar. for you to used the teg. rear sway bar think you will have to move it back to clear the rear end and down about 1.5 to 2 inch to clear the spare wheel pocket. the other thing you would have to do is swap the lca from L to R and R to L so that the sway bar mount hole is in the back side of the car to make up for the back movement of the sway bar itself. (the sway bar i'm using is made for a ef hatch which i think work the some way as the teg.)
hope this helps
check out the epic tuning EF on youtube.
here are some pic of my da1 seat swap, perfect fit....
Great ideas and projects so far, I will definitely be watching this thread for updates.
keep it up
wagon.....................4evevr......................
another idaho wagaon
i need to find some of those drop forks. i never knew about those.
hai: you have to come to the NW meet!
i want to see this in person.
