bypassed the ac pressure switch... Now on to the next step
Ac doesn't work on my new 89'. My friend that does home ac heating /cooling told me I need to find out where the pressure switch is, and bypass it. Then see if the compressor will kick on. and then from there add r-134a and go from there. There's no pressure in the system, but he said it's good that it wasn't under a vacuum.
So where's the pressure switch?
Trying to figure out if I need a new compressor/ receiver drier before it's hot as hell.
I figured that if the compressor was bad, that the button would still turn on, but there would be no activation of the clutch... or something like that.
None of the fuses indicate that they go to the ac. I guess I'll just pull the middle console away and start testing to see if there's even power going to the switch.
I would be nice if the manual covered anything about this. That little manual has proven to be a waste of money. It has not covered a single problem that I've had to work with.
I don't know what I'm doing... help!
22 degrees, dont ask me why
fanswitch/blower on
the ac&indicatorlight is connected on that fanswitch
position ground and numbered 6 is ac
what?
sorry, I really don't know anything about air conditioning. I'm not sure what to make of afaik : 22 degrees
But I guess your saying that the ac fuse is in the number 6 fuse spot.
it was a telegram
22 degrees celsius before the ac kicks in
(and i did ask, dont ask : )
your lightindicator of the ac is integrated with the fanswitch.
that fanswitchconnector is numbered...
so ground and number six makes your airco work and
makes the ac indicator light glow when you push the ac-button
check that line 1st, see quote above..
hope this makes sense
ps. not mentioning a fuse-position and/or spot
have phun : D
yeah, no problem
I've got A/C.
I never though I would get it working so easily, or so cheaply.
I love this car more every day!
