my 91 rt4wd [for sale] 90 sedan [new project]
well this isnt gonna be a full build yet cause im broke as of now. its gonna be slow and prolly nothing will be done again till the summer.
i picked up the wagon from ThinkFab. thanks for being cool and lettin me use some tools.
its a 91 rt4wd. a complete virgin...just the way i like them.
some stuff i did and wanna do
engine
-d16a6
-6spd
-LuK clutch (off eBay...hope it lasts)
-new timing belt/water pump
--plans
-d16z6 turbo/supercharged?
-OBD0 to OBD-1 for tuning
-steam-cleaned asap
interior
-scrubbed for like 7 hrs and its still not very clean
-Pioneer DEH-P6000 Head Unit
-Pioneer 5 1/4 door speakers
-Pioneer 6 1/2 rear speakers w/ speaker pods
-no further plans
exterior
-completely stock
-16" 5zigens/summer
--plans
-front lip (si hatch or da)
-full repspray...thinkin YR-88 w/blue metallic (lemme know what you guys think)
-new hatch
suspension
--plans
-full body coilovers either ksport or skunk2
-civic rear sway bar
first thing is the suspension. that will be this summer. that a6 still pulls hard and doesnt burn oil so im not worried bout the engine right now.
now on with the pics...
i pulled the motor and did the clutch timing belt and water pump. while i was taking off ther distributer i dropped the bolt into the bottom of the air box. the part that sits inside the fender. well this is what i found instead...the white circle is a mouse head. thats all thats left of him.
engine
-d16a6
-6spd
--plans
-steam-cleaned asap
interior
-no further plans
exterior
-completely stock
-16" 5zigens/summer
--plans
-new hatch
suspension
--plans
before
what i used
-water/303 cleaner/turtle wax armour all
after
never scrubbed just vacuumed. prolly will just replace or steam-clean
there was a rust hole behind the trim on the drivers side and just a lil rust on the pass side. both in the same spot. i welded metal in and ground all the rust off the metal. then i filled with fiberglass. its not perfect but its only to prevent further rusting till spring. i put tape over the holes for the clips. the mouldings will go back on this summer.
need to wash the fiberglass dust off my car
i also painted my valve cover for fun. still need to get my bay cleaned though.
i also found the infamous tail light leak.
lovin the wagon...
great speakers
dont like snow ...
or its XXXmas
after the bronze stripped off it was fully polished.
primer
white with a blue pearl mica added (cant see the blue until the sun hits them)
i bought some eBay strut bars. the rear bar was to long so i had to cut it down. doesnt look bad and made a huge difference. but i went to put the front on and the bracket that bolts to the body doesnt let me bolt the fuse box back down. it wasnt this way with my crx so idk what to do. i went and looked on eBay and the front strut bars for a 91 civic are all the same. anyone else with this problem?
i have one on my wagon. only one side of the fuse box wouldn't reattach, but it's still mounted on the other side.
yeah i got an ebay strut bar from a friend and it didnt allow me to bolt the front side of the fuse box, so i left it unbolted.
also the strut bar itself was too short, so eventually i just took it off cause it wasnt doing anything anyways.
There's plenty you just need to know where to look. :P
