86 4x4 budget project
well, picked her up last week for $66.99, couldn't pass it up.
definatly needs some work... currently doesn't run, may try wrenching on the motor if the weather breaks, otherwise, may just put together a browntop/dual weber setup over the rest of the winter.
If anyone has any front bodywork/windshield, speak up!
D
D
here's an auction for the nose pane, though yours appears to be ok.
http://cgi.ebay.com/ebaymotors/84-85-86 ... enameZWDVW
here's a new grille.
http://shop.honda-auto-body-parts-onlin ... -1340.html
it's usable, but far from ok. $40 for a new nose pannel... hrm... more than 50% of the vehicle price... think i'll pass....
Picking up a browntop this weekend... looking for DCOE 40's.....
RT4WD dohc zc sreamer, I can see this happening. 8)
:idea: Gutterslide has the right idea, never hurts to have some spare parts as well. :roll: OMG, I have a spare wagon
you mean 4x4 right??? :shock: no RealTime on this baby...
Hrm, i was under the impression that all 84-86 were the selectable FWD/4WD and 87 was the first year for the Realtime AWD.
D, what does you vin tag say for year and month of build. Do you have an owners manual?
I was almost certain that 84-85 had selectable 4wd and 86-87 had the center diff. But if what you're saying is true then you cannot switch your 4wd system off. :?:
I have a UK 1986 dealer brochure...it shows the 4wd is turned on and off with a push button switch.
I assume this is done the same way you manually disable the 4wd in the later RT versions (the slide lever). Just speculating, but that lever may be replaced with some kind solenoid that is controlled by the push button actuation.
That would be rather cool.
If you were into drag racing, launch with locked 4wd then after the 60ft drop it to 2wd..
My 86 has a pushbutton on the dash to the right of the steering column for 4wd. No center diff.
I'll have to get back about the year/month of build...
PLEEZE :!:
10-4. i'm on it.
ask and ye shall receive...
I'll grab some pics of the actuator on the tranny when i pull the motor out.
looks like we have made history already
I definately didn't know this :?
Does the 4wd image inside the gauge cluster light up?
You're assuming i have a battery in the vehicle... bad assumption.
:oops:
Progress
Thanks because I search solution for my mine
