crx si climate controls
will they fit/work in a wagon? i saw one on honda-tech and like the buttons WAAAAAY more than the slide controls.....thanks.
edit: this is the unit i am referring to-
unless you spend a good long amount of time swapping out the wagon HVAC system for a Rex one and wiring it and what not...
thats just what i think its like.
does look good though
funny thing is i was going to PM you and i thought, "nah, i pm him questions all the time i will just post it." and then you answer.
LOL.
Im no expert here as I havent tried this conversion personally, but this is the info I was able to scrounge up. Weterh its 100% or not, I have no way to verify.
From what I was able to gather when I was looking into this was that you need the lower half of the hvac as evol911 said (only I thought it was located behind the climate controls/stereo) where all the different functions of the climate controls change the flow of air. def, heat, face, etc. Basically where all the cables go to from your climate controls. The actual cables (wont be as many as a hatch or wagon), and the climate control unit (as pictured and rare I might add).
The EF9 controls are softtouch, which translates to electronics instead of cables. So instead of cables (there will still be at least one cable for hot/cold function), theirs wires that need to be run to control functions (hvac box). Im sure if you were to get some diagrams for teh CRX wiring, you can figure it out.
