JB2Wheels' 90 2WD TX Beater
This is what $600 buys these days:
I had to fix:
- clutch idiot switch - PO had wired a switch from batt to starter thinking he had a bad ignition switch - was missing rubber pad that pushes the switch, now it's a bolt
- fix brake light switch - same problem as clutch and was killing battery - same fix
- replace thermostat
- correct the cam timing PO had TB and WP replaced and mechanic got belt installed a couple of teeth off
Now it's drivable so next things are:
- brakes
- better hood - already found in local junkyard but the color's wrong
- scrub/pressure wash the gross interior and fix the driver's seat
- AC needs work - feels like the compressor is frozen up
- replace radioator - cracked where intake snorkle mounts
- stereo
- correct corners - already on the way
- tires, maybe rims
This is what it replaced - should double the mileage but giving up about 200 HP...
  • Hi i'm Steve : ), nice going...i was just wondering, 4what you needed 200 hp for...
    you doubled the mileage now with half the hp and more compared one to another
    pitty the wheels dont fit : )
  • jb2wheelsjb2wheels Wagonist
    Well, the extra HP was fun for smoking tires and surprising Mustangs ;-)
    Well, the locker room / ashtray of an interior is much cleaner now and it runs pretty good, too.
    I picked up some 17s for $105 with tires, Very happy.
    Still need to:
    - fix AC (compressor locked)
    - finish interior (waiting on radio)
    - pass emissions (2x HC limit at idle)
    - finish tint (those back windows are hard)
    Headliner:
    www.civicwagon.com
    Rims
    Gutted Inside
  • GREAT PICZ ... Happy as a lark ...
    Thnx
  • QdogQdog New Wagonist
    jb2wheels wrote:
    Gutted Inside
    Wow thats a cool pic! Great find, Awesome price!
    cute headliner :mrgreen:
