So Kripsy. Just dont ride around with the highbeams on all the time because those yellow bulbs draw out more power than stock and might drain your battery faster than the alt. could charge.
just received update that my bid on a pair of JDM EF5 rear corners was accepted thru YAJ... and because of my Newbie status, I am requesting wagodizzle to kindly explain how to remove my existing one's so I can replace w/ these. Thanks in advance dubdizzle...
where you insert the light bulbs on the sides of the trunk, remove those covers, each tail light is held on by 4 bolts, there 7 or 8 mm.
you can also pull back the plastic trim just enough to get a socket in there.
if you're replacing the other "flat" lights as well, you can pull that entire panel on the hatch off, it's only held in by screws on the bottom, theres about 10 or less of them.
ahahah those are actually some good qualities to be proud of!! shnap huh?
LoL it's all good my man!! You know you all are ALWAYS welcome to crash this Surfside Parlee...
those look really really good.
but im pretty sure Bosch Icon blades would have been better then OE ones.
just buy new tires ALREADY!!! you wont have a CAMBER problem after this weekend anywayz.....lol:)
