1989 Honda Civic Wagovan (EY3) - Metallic Blue
18911131422
    ThatDoodle wrote:
    205/40/16 on your Blue Volks?
    affirmative Nj, them be 205/40/16 BFGoodrich KDW's to be exact.
    not only is NJ a wheel whore but he is also a tire slut.
    ahahah those are actually some good qualities to be proud of!! shnap huh? :lol:
    Yes Yes I am a wheel whore and a tire slut. :twisted: I admit it! :twisted: Dont mean to thread jack jp.
    LoL it's all good my man!! You know you all are ALWAYS welcome to crash this Surfside Parlee... :D :) :wink: :shock: 8) :P
    I picked up a couple misc items for the Wagovan this weekend.... OE wiper blades and a pair of Halo super yellow 9005's
  • michaelhinkle1michaelhinkle1 Senior Wagonist
    those look really really good.
    love the lights man :shock:
    but im pretty sure Bosch Icon blades would have been better then OE ones. :)
    ya thanks bruddah's, and I'm prrreeety sure bosch aint got nuttin' on FREE oe honda blades! :wink: :P
    eh, free, yeah.. cant beat that :lol:
    not to mention, it seldom rains here in Daygo, so.... it's all good! :D
    So Kripsy. Just dont ride around with the highbeams on all the time because those yellow bulbs draw out more power than stock and might drain your battery faster than the alt. could charge.
    10 4 Doodle. :)
    just received update that my bid on a pair of JDM EF5 rear corners was accepted thru YAJ... and because of my Newbie status, I am requesting wagodizzle to kindly explain how to remove my existing one's so I can replace w/ these. Thanks in advance dubdizzle... :)
    open the "hatch"
    where you insert the light bulbs on the sides of the trunk, remove those covers, each tail light is held on by 4 bolts, there 7 or 8 mm.
    you can also pull back the plastic trim just enough to get a socket in there.
    if you're replacing the other "flat" lights as well, you can pull that entire panel on the hatch off, it's only held in by screws on the bottom, theres about 10 or less of them.
    appreciate the feedback M. Hinkle! :)
    no problem :wink:
    hinkle was right. lolz... very easy to remove :lol: takes like, idk. 1.5 minutes.
    ... and only Y3500 a piece... 8)
  • Your cars looking good. Hows the visibility with those yellow bulbs?
    Thanks tripleseven. The yellow bulbs are Ridiculously bright! Together with the Platinum 9006 headlight bulbs, they open up some serious visibility! :)
    wagon is lookin mad fresh; i like your style....
    EDM Tails....NICE!
    ^^ thanks guys... I'm bored, so enjoy this LGenvy snap* of my daily butter! :shock:
    where are your rims?
    In the garage chillen. The Falken's need to be swapped side-to-side because of the tread wear...(camber)
    JDM wagon with some USDM touches.... check out the rear window blinds! Geea
    Very cool Blinds!!!
    whose wagon is that?
  • jonjon Band Wagon
    those SI hubcaps should be on a EG not a EE.....:)
    just buy new tires ALREADY!!! you wont have a CAMBER problem after this weekend anywayz.....lol:)
    ahaha, I'm broke like a joke. Camber Kit = GEA!!
