someone CUT the driver side wiring harnes on my wago
i need to hook up the turn signal and bumper turn signal again. can someone tell me the wiring colors so i can hook em up again?? thanks
EDITED THE TITLE TO SAY CUT
if the wire were cut then i believe the bumper lense colors were green and black
yeah i was just looking at them and there are like 3 different black wires?? i hooked them up but got nothing. must be the wrong ground maybe?? i thought grounds didnt care??
you have to make sure that the three colored wires are correct though. also make sure they arent cut anywhere else!
oh gosh yes, just like my friend
WHITE/GREEN (CUT)
BLUE/RED (CUT)
RED/BLACK (CUT) (turn signal maybe??)
2 OR 3 BLACK (CUT) ????
GREEN/GREY??? (DISCONNECTED)
GREEN/RED??? (DISCONNECTED)
BLACK/RED?? (DISCONNECTED)
in other words it is screwed up!!! I know one of the plugs is for the washer fluid pump. the Big yellowish one at the bottom i dont know what it does. anyone else know what is going on?? Also there are a LOT of added grounds for some reason??? i dont know WTF is going on
if this isnt bolted on you wont have any ground. so step one is to get this grounded. there is a spot for it on the chassis, i can get you a pic if you need.
EDIT:: you posted right when i did...i am going to go outside and test those two harnesses and see if they blink. Thanks
i kid you not, i KNEW you were going to say something about that!!
