rear brakes: proper function question
After sitting for several years with some brake issues that are listed in earlier posts, I finally resolved my brake issue on my '89 wagon. I was sold the wrong wheel cylinders for the wagon. I have recently found new old stock wagon wheel cylinders and installed them, bled the brake lines, and I now have a good firm brake pedal and the car stops good.... almost to good. It has been so long since I drove it with decent brakes and I can't remember how they should respond.
When I get the car rolling at about 5-10 MPH, and hit the brakes pretty hard (like you would have to do in a hard brake situation) both of the rear wheels skid.
Is this how the rear brakes should work?
I just need a refresher.
Thanks
Frank
Thanks
Frank
Did you experience that at all?
I do not recall having an issue like you are speaking of with the wheel cylinder nuts. My wagon is a standard FWD model and it seemed like there was adequate room to get to the nuts. Seemed fairly easy. I did have the vehicle up on blocks with the suspension fully extended, so maybe that helped? What year wagon do you have?
In regards to rear brake adjust, should I bring the shoes back in a bit with the adjuster? I adjusted the shoes so they would barely touch/drag the drum and the wheel still spun freely, but man they sure work well. I may have to take it for a spin down the street to just make sure of the operation, even though the car isn't street legal yet. I'm ready to get it back on the road.
Thanks for the response.
It's been a minute since I've been here. Life crept in and I got busy. My apologies for the tardy response. In regard to my brake issue, it turns out that the parts store sold me regular civic wheel cylinders... and we all should know those will not work.... although the parts store insisted that they would since they were listed for ALL civics. I did a bunch of parts hunting and actually found some NOS wagon wheel cylinders (since it seems they are getting harder to find) and installed them. Within 2 go arounds of the bleeding sequence (probably could've just done one run through but wanted to be sure), less than a half a bottle of brake fluid, there was and still is a very firm brake pedal. The wagon has been driving wonderful and stops as it should with no more brake issues.
