My '91 RT4WD wagon [new pics of rt4wd rear sway bar setup!!]
here is my wagon that i picked up for $250. i plan on a z6 swap but not sure if just the head or whole long block.
i have an EG 4D too, which is my DD right now. which is also where i am sourcing most of the z6 swap from but its only a Mini-me right now.
the EG has a shopping list of mods but i want to completely convert to an EE enthusiast.
thanks for checking out my rides
yes they are. i wana see someone go all out and turn there wagon into a rally car
"These might have been posted before but worth posting again"
There are some good action shots of a wagon in there.
Hehe Mine didnt come with one either... i got one for it though =]
Neither one of my RT's came with a passenger mirror either.
Nice little wagon man! Welcome to the board!
this is the new rear cross member i got, before sandblasting and after.
before...
after...
now i have to add material to the cross member to make it stronger so i can rally in the SCCA next year i hope. when i get the old xmember out ill post pics of how bad it is.
i like those wheels too.
(it just needs to be dropped!)
i don't know about that... :P
its pretty bad, tis is my new and old next to each other
the new one looks like it came from the factory! i got the seams on the LCA mounts welded by a friend of mine, you can see the welds in this pic.
this next pic just makes the cross member look way out of place.
and after i replaces the cross member i did my exhaust, i used a flex pipe and a 2" inlet cherry bomb turbo muffler, it sounds almost stock, my roommate has one too but with 2.5" catback it sounds way different. well this is how it came out.
next thing i have to do is replace some front springs but thats a post for another day
great DIY exhuast!
I'll have to file that idea away and save these pix on my hard drive.
Thanks for sharing
Will you do write up on your 170hp mini-me build including how you use a obd0 B16 ECU???
i have posted a write up in the engine part of the forum hope you enjoy!!
Have fun in the snow...we're going to be getting a bunch more.
