1991 CRX Cluster and cluster cover on 1989 Wagon?
Ok, ok..... before everyone rolls their eyes and says this has been discussed, know that I have searched here and I have looked across other sites as well. No concrete answer!
I know that you have to repin the clusters/hazards n switches need to be soldered, and i know the clusters will bolt up with the right mounts. My question is if the CRX *cluster cover* from 90-91 will replace the 88-89 unit on my RT with no modification. Anyone have pictures?
I guess the question also involves if the 88-91 Civic HB shares the exact dash as the wagon. Because if it does, the cluster cover should* work from what I have read..
Nevertheless, I have a beloved 1991 VTi cluster that i want to install in my new 1989 RT4wd and before i purchase a CRX cover, i felt to ask all my wagon homies!
Thanks guys!
    bump for anyone with images of said swap!
    The cluster covers are not interchangeable between years without modification. Cant remember exactly off the top of my head other than I have both versions at home and the newer one didn't fit my 88.
    So the dash between the CRX and all civics is different? Hmmm. I may just have to get a cover myself and try. I think I did a few years ago and it *did* work. Ha.
    Nevertheless, thanks for chiming in man!
