Charging system problem
ugh...
i got the warranty replacement, put it in, boosted it up with my bro's civic for about 5 minutes. turned key, brrrrroooom. ran great, then died half way down the street. One by one the electronics go out, first tach, then radio, dash lights, headlights then car turns off.
i replaced the battery connectors
same thing.
must be battery now right?
The above quote came from a thread that quarters posted in in regards to problems he was having with his alternator a loooong time ago. I'm posting my problem in hopes of getting more responses.
I'm having the exact same issues as quarters was. Just as I finally get the correct CV axle, this problem occurs. Geez!
First I lose my tach, then the radio cuts in and out, dash lights dim and then engine starts to lose power until it dies. I had to get towed home yesterday because of this!
After I get home, i boost the dead battery with the wife's minivan. Almost immediately my wagon dies after removing the cables. I then rip out the battery from my dad's 94 Accord and swap it out with the wagon one. Bam. Instant start! Seems to have lots of power. I take it out for a spin and happily do donuts in an empty lot. Problem solved. (Or so I think)
This morning, my dad gets stuck in the snow as he is leaving for work. The roads around our house haven't been plowed yet. I am able to pull him somewhat free and then one by one I lose the tach, radio, dash lights etc. Bring it home and since my dad is already late for work, we got to town trying to figure out the problem. In the end it seems like the alternator got fried at the top connector (the one with the rubber cover) and is intermittently charging and not charging the battery.
Does this sound like a logical explanation for the problem(s) I'm experiencing? And if not, then what else could it be? We're going to swap out alternators tonight as my dad has one lined up already. Anything else we should look at?
Sorry for the long posts but I tend to get carried away when I'm writing! Thanks in advance!
volts if not its your altanator
my problem ended up not even being the alternator but the little ring fitting that goes onto the alternator. after changing absolutely everything, i changed that fitting and everything worked great.
good luck.
