dpfi-mpfi keeping automatic
 afidarkside
                Wagonist
afidarkside
                Wagonist
                    I have searched this and have a few questions, if anyone has done this.  I am not interested in changing to manual due to my wife not interested in learning to drive stick. lol.
So I have collected my parts, I will be using a ps9 ecu. I have everything I need for the general mpfi conversion for a manual. What is the differences in the wiring at the ecu for an automatic? Do i need to switch any additional or add additional wires because I will be using automatic? Thanks in advance.
Your going to need the pully and cable linkage from an accord or integra throttle body for the automatic transmission kick down. The wiring was um... fun to say the least. I did it by trial and error, since I hadn't found anyone before me that had done it. You can also use a obd0 auto integra ecu, for a more fun tune. I went back to the ps9 ecu eventually...
There is some pics of the throttle body in my black wagon build thread.
Finding a write up for this is becoming a pita. Any info would be greatly appreciated.
I just wanna keep my b2 head and block, keep auto, stay ob0 and do the mpfi conversion / swap the y8.
Is that too much to ask?
Since you asked- yes lol
My personal opinion, is you're biting off way too much. WAY too much. If you're not concerned with downtime, have at it and learn! If you are concerned with downtime, I say swap the motor in and get the car on the road. A multi port swap can be done on a Saturday if you have all the parts and information ready to go. As far as the Y8 manifold, its one more thing that you're going to have to deal with. I was real interested in doing it for a while. After doing my research, I decided it wasn't worth the effort.
Again, just my opinion...
Ill get it running dpfi but I REALLY want to do this at some point.
My Mad Max wagon is a mpfi with automatic transmission.
I used
- 88-91 civic/crx si intake & throttle-body & injectors & distributor & resistor box.
- 89-93 accord linkage for throttle-body and transmission kick down.
- PS9 ecu from 90-91 civic ex sedan.
I got my hands on an dpfi wiring diagram and a mpfi civic ex wiring and then a little trial by error.
I enjoy the swap. I'd even do it again. I managed to find a spare ps9 incase I find a sedan that I want to do it to or another dx wagon.
The ecu is probably the hardest find.
If you want to keep it automatic, then it's worth the hassle.
Here is the link to mine:
http://www.civicwagon.com/showthread.php?13100-DRMORTY-Fun-w-quot-Dick-amp-Jane-quot-is-now-Mad-Max
The ecu is a pm6 and the rest is just wiring it up and a few reprints to the sockets and plugs and such.
Im going to have him do my electrical. He said he can don it, no sweat.
The accord linkage is useful info. I heard you can also use a prelude tranny cable and modify it to shift quicker.
Aand ill be done. Minus the throttle linkage of course.
The rt4wd has a stand alone transmission shift computer. Located under the passengers seat. And they use a manual pm6 ecu.
You need a automatic ecu. Ps9
