Speakers working oddly
 SPW
                Senior Wagonist
SPW
                Senior Wagonist
                    We'll the other day I plugged my iPad with an car aux plug to my radio. Then I plugged it to charge from my cigaret lighter. After I turned on the car it was making scratchy noises almost like when a TV looses signal. Then I unplugged my iPad from the aux jack and charger and my iPad was fried and shortly after there was a burnt smell. So I switched my iPad for a new one and plugged it with a car aux plug again my radio works still and now my speakers sound echoey and the lows from my speakers don't work either there just plain horrible and my sub does not work. All I've done so far was checked my fuses except the one on the back of the radio. Anybody know what could have happened? What do you suggest doing? Thanks civicwagon.
Do the speakers sound like they're clipping at all? Was the burning smell from the ipad or somewhere else in the car?
It sounds like you may have a short somewhere, that would explain the burning smell, especially if it's continuing after the initial problem. It could have caused your amp to burn out, or it could just be a short within the amp itself.
If the wires to your sub are all good, and the sub itself is good, and it still isn't getting any signal, it's most likely your amp, which isn't delivering nearly enough power to even make the speakers move. This could also explain the lack of lows in the other speakers - low frequencies typically require more power to produce. Did you use an in-line fuse when wiring power to your sub? Check that if you did.
A bit more technical info on clipping:
https://en.wikipedia.org/wiki/Clipping_(audio)
Ya might try wiggling the aux cable around in the input and see if you get any change in sound quality, etc. (just make sure your volume is low!) If it's poppy and cuts in and out, etc., you've probably got some bad solder joints or something.
Worst case scenario, sounds like you may just need a new head unit....or if you don't ever use the radio or CD player, just go straight from your aux source to your amp (depending on how you've got your whole system set up)
