won't start in cold weather
Alright, high miles 91 RT. Been running great all year long. Needs an engine swap as I'm about 500 miles from hitting 260K and it's burning a little oil. Got into 20's the last two nights and won't start in the morning. Hit the key and dash lights up, main relay switches and it clicks under the dash, but the starter doesn't budge, nothing. Yesterday, I had my girlfriend try and start the car mid-day and it started right up. My initial thought was the clutch switch, but being it's starting up in the warmer temps, maybe not. I'm kind of puzzled, so throwing it out there for any suggestions or advice. I haven't had time to break out the multimeter and test at the starter and that clutch switch, but it's on my list of things to check. Any other obvious ideas? I also thought it might be coolant freezing, but when I checked, it was full and looked pretty green.
Thanks guys!
Thanks guys!
I always have the motorbike as a backup, but that's no fun when it's 30 degrees out. Thanks for the help guys.
Turning the key to so the engine light comes on, but not fires up, also primes the fuel pump. Which IMO, is more important. I try to do it even in the summer months.
When it doubt, bash something. Like the fuel relay. if your car is cranking but not firing, bash the fuel relay just above the hood release. 9/10 it fires up.
