22mm Mugen rear bar install
I had been using oem DA brackets, but the thickness of the bar was stretching the bushings to pieces and it was real squeaky.
Enter ES 22mm bushings with brackets. 2x as thick and beefy as OEM honda. Plus i got the grease able kind.
Took factory wagon tow hooks and welded on some L channel, drilled out the holes where i wanted them, done.
  • How is the car driving now? It gets a bit scary withouth when hard braking in the corner, sometimes the rear wants to slide a bit too much I think...
    With my LSD, all i do is get on the gas and it pulls me where i want to go :)
    I find the back very manageable, i can get it to come out just by coming into a corner hard and then letting off the gas, no brakes required.
