91 wagon wont fire when hot
 Evan_Lovell
                Band Wagon
Evan_Lovell
                Band Wagon
                    After i get up to running temp, turn it off and let it sit for 10-15 minutes it wont start. I get two reactions.
1. it will just click when i go to start it. when it does this i turn the ignition 2-3 times and it starts right up.
and 2. it will crank but not fire. when this happens i have to wait for it to cool. (5 more minutes)
I replaced the main relay, plugs, wires and fuel filter all in the last 3 months.
Any ideas or solutions would be greatly appreciated. Thanks guys.
Try replacing the ICM (Ignition Control Module) in your distributor. Mine went bad. I popped a new one in and haven't had any problems since.
It will die on me from time to time. But before it does the idle will jump around then die. I was told it could be the ignition switch. But I don't see how the ignition could cause it to act like this when its hot or how it would make the idle jump and die.
This is news to me. Possible I missed it.
I told ya, try it, if it doesnt work- RETURN.
What do you have to lose? The answer is- NOTHING.
If the CEL stays on it's usually ecu or ignition switch, but even if it turns off it could still be ignition switch.
