Factory plug ECU pinout Diagram
I am swapping a b20 into my car, and I bought a obd-1 rywire harness for my engine. It came with sub harness the plugs into the rywire engine harness. On that subharness there are 9 white loose wires with color codes on them. I was told I have to splice these wires to my factory ecu plugs. The problem is I first off have to figure out what each color code on the white wire does, than I guess match them to the factory ecu plugs. Rywire sent no instructions what so ever.
https://www.google.ca/search?q=ef+ecu+pin+outs&tbm=isch&tbo=u&source=univ&sa=X&ei=nRPjUaXjMYuhyAHfi4GAAg&ved=0CCwQsAQ&biw=1600&bih=880#facrc=_&imgdii=_&imgrc=LeDK7swYrNaGwM%3A%3BtfHj6zQ_fB4fOM%3Bhttp%253A%252F%252Fcivic-eg.com%252Fpics%252Fecu%252FECU_pinout_obd0.jpg%3Bhttp%253A%252F%252Fwww.vadriven.com%252Fforums%252Ftech-talk-9%252Fneed-help-obd0-ef-intake-air-temp-sensor-447663%252F%3B779%3B952
