My RT4WD wagon!
Hey fellow wagon members!! I recently got me a 1988 civic wagon that is a RT4WD model!!! soo stoked to get this, and it has little body damage and no rust!!
I had to get the front ball joints replace, same with the upper control arms, and the alternator.. now its go time for this! I was up at college when i bought her, talked the guy down to 1300! she has 262k and the engine was overhauled... got more parts comming in the mail.. some necessities like bushings and so on... well here is some pics!
  • SWAGOVAN_AKSWAGOVAN_AK Band Wagon
    So it was time to leave college and go home.. finally! hah the drive back was soo boring, but the fact i was bringing the wagon home made it worth while..
    SNOW IN MAY?! you never know what the Alaskan weather will pull on you....
    so i ordered some new LCA's and Ksport coilovers, they finally came in yesterday and i started to go to work!
    OUT WITH THE UGLY IN WITH THE NEW!!
    oh yeH the guy before me put it on ebay coil sleeves.
    the back is dumped the furthest it can go and i still want to go lower in the future... what should i do? cut the springs or get replacements?
    my driver side tire is noticeably closer to the front bumber compared to the other side.. what can i do? adjust the radius rod that goes from the front subframe to the LCA?
    DRIVER SIDE
    PASSENGER SIDE
    more to come! :)
    ladadeedaa
    Well when i went to replace the front suspension, i was halted with things i didn't want to see...
    my axle boot on both sides are shot... have to take apart everything, im probably going to get new axles..
    just some Drive-shaft curls ;) haha
    SO! my day goes bad to worse... the lower control arm wont come off the lower ball joint on the passenger side.. I got a puller and everything and i put to much pressure on the ball joint bolt and i squished the damn thing....
    it just wont come off!! i think im going to take the whole nuckle off and take it to a shop.
  • realtimefunrealtimefun Senior Wagonist
    nice wagon man
    nice wagon man
    Thanks man! I can't explain the emotion when I first got her... :)
  • SPWSPW Senior Wagonist
    Looking good man! Any wheels you have in mind?
    I was thinking stick with these old school enkies!! they have brand new all-terrain tread so ill be good in the winter and I think they are dope AF! but later on i want to go 16in or 17in rims... or gold 82 enkies, when i get my paintjob... Stock color is my plan, I know it'll be dope.
    i mean enkie-92's
    I finally got all my parts in the mail, bushings for the front LCS and sway bar attactchments, and for the rear differential mounts, trailing arms, compensators and upper control arms.. i took a trip to orileys and got new axles, outer steering arms, and a lower ball joint.. Now i just have to take the passenger side knuckle into the shop and get a new ball joint pressed, and get the damn lower control arm off the ball joint!!
  • nice wag yo.. I got the exact same one for 275. trying to her on the road wit some steez too.. I need some coil overs like you.. I want to go really low to but want the option to be able to adjust back up incase i want to hit up the mountain or supm ya know?
    Good work so far. You should be able to rent a ball joint separator at O'Reilly, or just buy one cheap. I'm sure you already have, but keep the area sprayed with penetrating oil. Once you get the joint separated from the LCA there's just a snap-ring retaining the joint in the knuckle. It's not really press-fit, you can hammer it out.
    As far as the difference in your front tires, look closely for something bent or loose. The radius arms you mentioned do control that, but aren't adjustable.
    you got your wagon for 275 bucks??! im going to keep the back how high it is, the coil is dumped. and a little lower in the front.. and yea i live in alaska and the snow is a bit of a problem... but last winter i rolled around int my accord, which is on coils to, and it was fine.. One day i had to plow through some snow, lol.. but yea all new bushing, simple things needed to drive smooth.. im going to get new engine mounts and fill them with urethane.. when i idle my car shakes.
    Thanks! I need these small upgrades. I did get a separator! It wasn't sophisticated enough, it bent my old ball joint..I sprayed it with PB blaster... put so much damn pressure on it and bent the bolt.. I got the other side off though.. the LCA is stuck to the ball joint.. Im bringing the whole knuckle in with the new ball joint to get it fixed..
    And the driver side had a front end collision, nothing to bad, but others have said that my front bumper may be pushed in.. also going to swap my Hatch headlights to my wagon, they are light crystal clear! I got them off a parts car for cheap.
    bam-bam wrote: »
    The post above was meant to quote your post. haha but yea next in line is body work! :)
  • you got your wagon for 275 bucks??! im going to keep the back how high it is, the coil is dumped. and a little lower in the front.. and yea i live in alaska and the snow is a bit of a problem... but last winter i rolled around int my accord, which is on coils to, and it was fine.. One day i had to plow through some snow, lol.. but yea all new bushing, simple things needed to drive smooth.. im going to get new engine mounts and fill them with urethane.. when i idle my car shakes.
    YA duder 275 bucks! mind you i had to buy a new engine but hey thats what makes it a fun hood ride build right?;) Im doin body work now too.. I went with the zc non vtec krate engine from japan under 50 k miles its in my build forum. I kinda wish i would have waited and gotten a d16z6 v tec but i might jus boost my zc effit.
    my engine runs strong i love it! just my power steering has been leaking and grime is everywhere in my bay... so ive been rocking the wagon without power steering... im thinking about just keeping it out. but yes thats my big goal for my wagon, Z6 swap then later when i get my cash flow game, ima turbo it..
  • PavementwagoPavementwago Senior Wagonist
    Not sure what everyone's looking at but your wheel is fine. Your bumper is what's the problem
  • my engine runs strong i love it! just my power steering has been leaking and grime is everywhere in my bay... so ive been rocking the wagon without power steering... im thinking about just keeping it out. but yes thats my big goal for my wagon, Z6 swap then later when i get my cash flow game, ima turbo it..
    Ya my car is leking power steering floid allover the place too but i dicovered that i got a loose hoes i need to fix her. So you say you want a zc or a z6? Btw how much did you pay for your suspension set up Im tryna decide between what you got and godspeed.
    Yea i need to find out where mine is leaking too... its a oily grimy mess on that side... and a Z6 swap. and i got a good deal on mine i got the coils and the control arms for 800. but check the sticky on Hondatech on suspension.. what to get and what not to.. then make your decision.. great detail and low price setups..
  • Yea i need to find out where mine is leaking too... its a oily grimy mess on that side... and a Z6 swap. and i got a good deal on mine i got the coils and the control arms for 800. but check the sticky on Hondatech on suspension.. what to get and what not to.. then make your decision.. great detail and low price setups..
    I think im jus gonna turbo my zc effit.. Maybe later il go with a z6 or a b20 and a crv tranny haha.
    Idk dude ive heard alot of good things on k sport.. Can you refer me to the place you got yours?
    Those old school Enkeis are sick! And..How can your drive be boring?? That scenery is beautiful!
  • That mountain range does look amazing man for sho. And btw those rear flaps look different. Ive never seen any with mountains on them. I know those arent stock?
    no those are just cheap ones from an auto parts store.. im about to have some si flaps thought. I cant come by a 4WD pair, and ones are ebay are expensive
    Thanks! I snagged them off craigslist a couple years back for 400 bucks, new all terrain tread too! muahah this winter will be fun without studs :) And the ride back from fairbanks was alright,, mostly because i didnt eat that morning and had to much fun the night before.. haha so i was really tired. I wish i took pictures with all my college crap in it. hah all on a blown passenger shock on ebay sleeves. Filled her half way up with premium though, on accident. I say it gave the wagon a bit more power haha
    yea hopefully they will do me good for a while.. and passwordjdm.com
  • no those are just cheap ones from an auto parts store.. im about to have some si flaps thought. I cant come by a 4WD pair, and ones are ebay are expensive
    [h=1]Wagon parts/garage clean out! WA hope i got this paste right lol anyway its from the parts. theirs a dude selling all 4 flaps in mint condition for 80 bucks including a 4wd pair bra lol scoopem up. and hey where did you pick up your suspension i want the same one for my wagsta?[/h]
    I posted the website in my comment before yours bro
    so the wagon has been out of commission for about a month now.. and finally everything is ready to be put back together.. but i want to upgrade my brakes to DA integra ones, rotors and calipers.. since the rotors have to get turned to be smooth, so why not just upgrade when you have everything disassembled.. 308.jpg
    so i got new bushings from honda,, got OEM RTA bushings, I researched more and found out that the ES RTA bushings are crap.. and got new front LCA outer bushings..
    The RTA bushings are pretty easy to flex from side to side.. is that ok? i got some plastic sleeves, honda recommended so the bushings don't squeak on each other.
    I was bored.. lol artsy
    Wire wheeled my metal components.. like the forks and control arms.. turned out pretty well.. i got some rust protect spray paint.. havnt sprayed them yet
    the one on the top is cleaned.. a before and after pic..
    then i got the wheel wells empty, rapped my alternator with a bag, put clean rags in the shaft openings, and sprayed diluted purple de-greaser all over.. i have rustoleum undercoating for wells.. hav't sprayed it yet either..
    before
    after
    Looking to spray my eninge and clean the bastard! but the main goal is to get the wagon on four wheels again., have all the new bushings put in, and get an alignment.. hopefully she will be done this week!
    Nice work! Can't wait to see it rolling again.
  • MexiChriSMexiChriS New Wagonist
    Cleaned up that fender well very nicely. I have to do that to my CRX Si soon.
