cluster lights
cluster lights not working i checked fuses and wiring also bulbs and nothing. HELP
  • bump, im in the same boat as you
  • maybe you turned the knob accidentally and turned them off, ive done that on several occasions
    this one?
  • the other night i removed my cluster and cleaned
    the connections, reinstalled everything and made
    sure connection snapped back inplace,
    in my case the connectors were very dirty and after
    i reinstalled everything i turned her over and
    cycled through the gears and BAM! it
    worked, might just be me but it's worth a shot
    might be worth it to note, mine is an automatic
  • jpciiijpciii familEE
    I had a 91 hatch with the same problem - switches checked out good. Removed the cluster, bulbs, everything looked good. Then I plugged it back in and the lights worked again.
  • Vince52Vince52 Band Wagon
    Will try again this weekend, a friend also said to try changing the dimmer switch?
    So i unplugged everything and plugged it back and still nothing, when i open my door the lights dont turn on either im so bummed
  • Sounds like a fuse, I would check them all again. There are a few in there that aren't labeled as well as they could be and can effect things you wouldn't expect.
