Electrical Problem After Swapping Pedals - What have I done??? Headlights turn on CEL
I need some help...really badly. I have a 91 DX wagon. All drivetrain and electrical is stock, as far as i know.
I just went through replacing my pedal assembly with a CRX pedal assembly, which involves taking out the seat and fuse box & dropping the steering column. When I put every thing back together, I was a little too eager to start the car and run it, and I may have made a big mistake.
I did not reattach the "MAIN RELAY" part number RZ-0063 to anything. Truth be told, I can't remember for the life of me where that metal bracket attached. I am not sure if that is my biggest problem honestly. Is the metal bracket on the back of this relay a grounding point?
When I started the car, It ran for about 5 seconds, the check engine light popped up and the car shut down before i even turned the key off.
Now my headlights turn on my check engine light, the defogger switch turns on a buzzer, the hazard button makes the heat gauge go all the way up.
The "alternator solenoid valve" fuse was blown.
When i attach the battery I get a dim CEL, if I turn the headlights on i get a bright CEL, even if the key is off. The car starts and runs. But the CEL stays on.
I am pretty handy when it comes to turning wrenches, but am terrified of electrical stuff. There is a very discouraging electrical fire smell in my car.
My main questions are:
1. Are there any 2 plugs on a stock wiring harness that i could have just plugged in backwards or accidentally swapped while putting the fuse box back in?
2. Where do I bolt part number RZ-0063? (photo encouraged)
3. Should i be trying to pull back my passenger carpet and start checking the CEL codes? ..or am i just Boned?
New engine/wiring harness/eco was my plan from the start, but i am not ready for all that yet. If anyone has any suggestions please help.
I can post a youtube video showing how it's acting if someone thinks that might help. I did my best to search the forums for this type of issue and i had trouble finding what a was looking for. Feel free to call me a noob, and then add a link to helpful threads.
Thanks in advance for the help
- M!KE K!NG
- M!KE K!NG
I JUST FOUND OUT THE PROBLEM. Apparently I am the only person stupid enough to ever do this (or the only one shameless enough to admit to it in the forums).
There are 2 identical plugs that go to the fuse box. Identical, except for the fact that one is blue and one is white. I had the blue one hooked to the connector that is attached to the side of the fuse box. I had the white one hooked into the middle of the box where the blue one should have gone.
I still can't believe i did that.
Replaced a few fuses...hooked everything up right...and now all seems right in my little civic's world.
I almost did the same on my ITR, had to google myself a fuse box diagram to find out where they went (my diagram is in Japanese and was of no use)
