jeff's 1987 isuzu pup
this is my 1987 isuzu pup that i bought for $600. i put in a clutch, and a radiator. it has a bout 115,000 miles. it is a 2wd 1.9 liter 4 cylinder 4 speed. it gets 28-30 miles per gallon, and is very slow. it was originally white with towing mirrors. so i shaved them and put 3'' peep mirrors on the doors. i painted it black, and it came out like herculiner (my brother told me it was most likely because i was moving the spray gun too slow.). so we sanded it down a little bit and he painted it charcoal metallic and we added a lot of royal blue metal flake.[IMG][/img]jeffsisuzucivichearse003_zps3cf2712b.jpg[IMG][/img]jeffsisuzucivichearse001_zpsf28bce50.jpg[IMG][/img]jeffsisuzucivichearse002_zpsc932cb07.jpg[IMG][/img]jeffsisuzucivichearse008_zps7f80a76d.jpg
  • I have one of those in my driveway. It's 4wd and the cab was destroyed in a rollover, so I'm building a new top for it.
  • [IMG][/img]jeffsisuzucivichearse007_zpsf0fd38a4.jpg[IMG][/img]jeffsisuzucivichearse006_zps5bca77f4.jpg168.jpgthis was my first attempt at making door panels. they were easy on this truck because it is a flat panel.[IMG][/img]jeffsisuzucivichearse005_zps1b58dfc8.jpgi had to use lawn mower tires as speaker pods because the kick panel is too shallow. they fit perfect with some metal roof screws.
    My good friend has two of these and loves the little jokers. One has a Weber kit on an offenhouser intake and headers. still won't pull the hat off your head!
    Question for you: where can we find a heater core for an '86? he says they aren't available? I haven't looked.
    edit: If I ever run across a decent diesel Spacecab, I'll probably snag it. I pour out enough diesel fuel daily at work to commute on!
  • the weber carb is a nice setup. my brother, friend and i have talked about putting a chevy 305 we have in it, but the 1.9 runs great, and almost 30 miles per gallon is nice too.
    i checked a couple of suppliers that my job deals with, and i dont see a heater core available for an 86-87 isuzu pup.
    i know some parts are the same from late 70's-early 80's chevy luv trucks, and early 80's s10.
    one of these might look the same as what is in your friends truck. here are some napa part #'s:
    660-3268 83 s10 with ac
    660-3269 83 s10 no ac
    660-3523 80 luv
  • SiRgeSiRge Wagonist
    That looks the same as what's called Nissan Navara over here in NZ, pre facelift front end. Maybe worth a look at a Nissan dealership or something for the same era model?
  • NZ-DB8RNZ-DB8R Moderator
    SiRge wrote: »
    No it doesnt, its too small.
    Is more like a old Holden Rodeo, and since GM owns both Isuzu and Holden it even makes sense:
    http://i218.photobucket.com/albums/cc195/crrrazytim/timdaddydogsfonepxt325.jpg
