Where do these these pesky wires go to exactly?!!
 outcast
                Band Wagon
outcast
                Band Wagon
                    So life got in the way and it took a lot longer then I'd care to admit to get the engine back in the 91 RT4WD, and in that time I've forgotten a few things.  Right now what I realize I've forgotten is where these three electric lines go.
I'm pretty sure that line A that comes out of the harness just out of the top of the picture attaches to the body with a bolt that also anchors the air filter box. I'm also pretty sure that line c that comes from the negative terminal of the battery connector and bolts directly to the body just under the battery tray as shown. Line B that comes off of the positive harness from the battery is a complete mystery. Any suggestions where that one goes?
And just for reference, we're looking down at the battery tray on the left side of the engine bay with the bottom of the picture being towards the front of the car.
Thanks in advance all for the help with this, and it's good to be back.
outcast
outcast
C is the ground cable, and its mid-terminal should already be bolted to the body under the battery tray. The terminal you indicate bolts to the clutch cable bracket on the transmission, as humorwvp said.
