EDM Gauge Cluster
Would the EDM gauge cluster fit the wagon? 90-91 civic hatch edm gauge cluster?
Is it plug and play, or do you have to re-wire some wires around?
it is NOT entirely plug and play. the wiring is a little different, so you will need to switch out the back panel electrical sheet from your original and put it on the EDM one. very simple to do. i have done it a few times
