Roof rack removal help:
I generally just go at it learn as I go but do not want to damage the roof, mounting hardware or the rack itself. I've searched but just wanting to be sure I remove it w/out causing damage.
Thanks for any info, help or write-up's.
:encouragement:
  • what was the question? damn....you need to specify and elaborate!
  • The rails are simply screwed in threw the roof (rivnuts protrude through, so no nuts on the bottom side) - get yourself a philips and remove the 3 per side and you're done. The crossbars I am assuming you don't need help with since my 2.5 year old son figured those ones out.
