Help! Driver side axle with d15 in RT4WD.
I know iv read on here that you can put the d15 in a Rt you just have to use the long axle, But im running into a problem the cv joint is hitting the transmission.. Is there a spacific year axle you have to use or do you have to modify it at all? I need help asap please!
You'll need an engine with at least the pad for the intermediate shaft.
