Cali Wagon Build
It's been 4 years sense I start this build thread lots of parts have been replace lots of stupid mistakes and lot has been learn from it
I'm rewrite this n starting this thread over
This is my 1990 Honda civic rt4wd wagon build fully stock
I found this car on cragslist for 1500 I didn't have the cash at the time so I told my buddy about it he got it for 1200 n resold it to with payments for 3000 bucks it had 174000 miles on it front seat was ripped Crack on the windshield front n real bumper was warped .
I have big plans for this wagon n will take me long time to build it.
But I'll start with the basic maintenance
list item that have been replaced with in 4 months
Brake pads and rotor were done
Napa auto tune up
NGK wires and plugs
Distributor cap rotor
Belts replaced all fluids fresh oil changed using amsoil OE full synthetic
All gaskets were replaced
Alternator after it went out few month after i got the car
Thermostat
Cat and exhaust pipes had to be replaced had rust holes in it
Timing belt and Water pump was done too
Radiator hoses
In 2014
I picked up a sum what built d16y8 was running a turbo on it. it came with following parts
Aem fuel rail
Aem cam gear
crowler stage 1 cam shaft
3 H beam rods
3 ycp 9.0.1 75.5mm pistons
Supertec valves & springs
APR head bolts
block of guard
it will be sitting in till I get all parts for it
In 2015
so far i done and picked the following items
had it taken part
pick up H beam rods
set Ycp Vitara 75.5mm 9.0.1 pistons
Oem head gasket
main bearing
Dry sleeved the block
used d16z6 crack shaft
skunk2 pro manifold
skunk2 70mm throttle body
p28ecu
BWR coilover and radiator
skunk2 rear camber and Rear LCA
Tru heart Front Camber
never used XsPower Turbo kit baby turbo
Obd0 to Obd1 jumper harness
Rain Visor
[h=3][/h]Stock pix when I picked it up [IMG][/img]
[IMG][/img]
Napa auto tune up
NGK wires and plugs
Thermostat
Radiator hoses
In 2014
Aem fuel rail
Aem cam gear
3 H beam rods
APR head bolts
block of guard
In 2015
had it taken part
pick up H beam rods
Oem head gasket
main bearing
skunk2 pro manifold
p28ecu
Rain Visor
[IMG][/img]
The paint was ok lot of scratches an dents every were even few rust spots
It need paint job dont really have cash for 3000 paint job so i didnt me self did it come out bad ? i think it looks pretty clean
-pauses.
*walks out...
yea i saw some one talking about that am gonna try it when i get chance to
I think the colours look good together, personally after owning a car that I painted with rattle cans I wouldn't do it again but that is just my opinion. The upkeep to make it look presentable is the pain, once the paint gets hammered by the sun it tends to look somewhat more average than it did originally even after washing the car.
right now i been replacing part new altnator all new belts new radiator new hose new P/S lines new spark plug an wire Cap an rotor new oil change
New Head gasket valve coverGasket new timing belt an water pump new Starter and the thermal stat that what i have done so fare
still need to replace shocks brakes pad an rotor flush the tranny and put new clutch in might have to replace the cat
basic trying to get back to so setting so it pass smog then ill start lowering it and mybe do mini me swap there lote little thing i need to do still
need to fix that front bumper pull thoese dents strip the car an im gonna repaint it with a gun
IMG]
mine does exactly the same! what the hell :S
p.s you should paint the spoiler brown to match the trim!
Fixed it for ya.
OP really hope you took it down to factory paint before respraying. Otherwise you could probably wipe it off with goop off.
I got some new 15 inch enkis. Rims with falcon tires I got come adjustable coil over but it sit to low so I ended upwith toykito blue shock n eibock lowing springs
Front slotter performance brembo rotors customer rt4wd Hood bra
Jdm rhd sun visor
Still working on sanding for paint job n haven't had a chance to install the sun roof
Out of a crx si yet
