ordering honda b series bearings need some help
so im rebuilding a b20z2 and i wanna use oem bearings im just confused on how to ID the main bearings this is a first for me i downloaded a crv service manual pdf to do this the right way i don't quite understand this chart
Heirs my crank i used red so you could clearly see what its stamped and where i know its upside down but thats so you can see whats stamped on the block aswell
this is all i could figure
ill be buying these off majestic Honda's web site sine they seem to have good priceshttp://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CR-V&catcgry2=1999&catcgry3=5DR+EX&catcgry4=KA5MT&catcgry5=CRANKSHAFT+-+PISTON
but its listing things weird like bearing (A-upper-blue) bearing (B-upper-green) and so on just need some guidance on this for my first build
    If your crank is standard size than your bearings should be standard size also. They should have the option to be standard size or oversize. When I took my crank in to get polished they told me what size bearings I needed to get. If youre unsure of what size than take the crank to a machine shop and have them measure it for you. Hope this helps.
