D15b2 auto to d16z6 manual I need help
I have a 90 wago automatic with dual point and I have a parts car 90 hatch with a d16z6 in it I want to put the z6 in my wago I've been reading and it's all so sloppy idk what to do things I have
D16z6 I think they used its harness In the EF I also have the ECU an I have two sets of manual linkage and pedals one set of cables on the EF and those motormounts I also have a crx si harness intake injectors etc ECU I basically need a write up o what I need to do where to start I'm pliny the z6 engine out of the EF this week
  • you would have to convert the wagon to multi port fuel injection for the additional 2 injectors. you will need connectors off of the crx si harness, and add them into your stock wagon harness. there are a lot of writeups on the dpfi to mpfi conversion. i would probably start with the auto to manual conversion.
