Abnormal charging issue (86 4wd)
 wagonsrfun
                Band Wagon
wagonsrfun
                Band Wagon
                    Background Info:
I bought the wagon in a non-running condition. Installed a weber carb, new head gasket, battery, and alternator.
Currently the wagon runs great, but does not charge.
below are the voltage readings I measured at the battery
car off : 11.5
car on : 11.48-11.5
car on with head lights on : 10-11
I even tried running a 6ga wire from the alternator to the pos batt terminal, and measured similar readings.
Am I up against an odd ball problem resulting from my carb swap?
Is there something weird about the voltage regulator circuit I dont know?
The alternator I removed from the car tested OK, I replaced it because I figured the regulator was bad.
Thanks in advance
car off : 11.5
car on : 11.48-11.5
Thanks in advance
Check the easy stuff first, as always.
Yes, the batt. connections on the pos/neg posts are good. Maybe the chassis side of the neg cable is corroded...
fuses are good (under dash and engine bay) At this point I have 6ga wire running from the alt to the pos batt, and from the neg batt to the trans ground. Still without any charging...Even tho the batt is new, I am going to throw in my celica's and see if that works.
Problem solved!
Seeing that I have changed multiple wires/components I should have re-checked some points along the charging circuit throughout the process. I must have arced the alternator at some point cause the under dash alt fuse had blown after I checked it yesterday.
In regards to your above note, I am pretty sure the alternator grounds from its own housing straight to the mounting bracket. I think the other alternator wires are for signaling the electric choke to engage and for the dash warning light.
I apologize for the mundane post! new to this forum but not auto forums in general, so i know how the boring posts can get old...
Thanks again
That makes sense. I've never had a charging issue with these cars so I have never taken the time to figure out exactly what all the wires going to the alt do. Thanks for the info!
