90 dx hard to start after sitting a day or two.
After my wagon sits a few days it will not start. The motor just spins. You have to pump the gas a few times and eventually it will start up. It will start and run perfect after that initial start and as long as its being driven. When I park it and it sits a day or two, same problem. It's got a fairly new main relay, new dist. cap and rotor, fairly new plug wires, plugs and a new ignitor so I don't think fire is the issue. The fuel system seems to not be priming on that first start up. I'm not smelling any fumes. A mechanic told me to turn the key but not start the car a few times then on the 4th or 5th time try cranking the car, same result. I assume this is an attempt to prime the system.
When the car does eventually start up, I hear a muffled backfire under the hood then as I said the car is good to go.
The engine is 100% bone stock.
Any suggestions? Please Help.
Thanks
Thanks
Another thing I've run into a couple of times: a faulty coolant temp reading can cause flooding, to the point where I had to Clean or change spark plugs.
flow test the pump, pressure test the fuel system, replace the fuel filter if it is old.
confirm the injectors are spraying good- mist is good, drips/stream is bad.
could you have water in the fuel?
Thanks for all the hints and suggestions.
