My 91 civic wagon has an idling issue and sometimes wont start unless given some gas?
Hi, first off i want to start off by telling you my make and model: 1991 Honda Civic Wagon Dx d15b2 engine bone stock.
My car has been having issues starting up and sometimes it would start up and shut off due to low rpm at stops it would drop to about 500 rpm and sometimes lower :x. anyways i haven't looked for any vacuum leaks yet but im pretty sure it is a vacuum leak because i have one vac line that is cut and has a screw in it so it wont suck up to much air(i bought the car that way). I am having trouble locating were the hose is supposed to plug due to it being cut short and all. I would really appreciate it if you can take some time off your busy time and take a look at your engine bay and help me out! here are some photos of what im talking about. It is right under the throttle cable. any help will be greatly appreciated i will also be cleaning my iacv and checking all my hoses once my money is in. Thanks in advanced!
yeah i checked under the hood before anything and the previous owner had actually painted over the diagram but i think i figured it out i just need to know the name of that part or im just going to scavenge for one at a local pick and save...
