Cabin Air Filter retrofit for 4th Gen Wagons?
Has anybody done anything like this for a 4th generation Wagon? I found a pretty good write from a guy doing it on a 5th gen Hatch.
[DIY] Cabin Air (A/C) Filter retrofit for 92-95 / delSol / 96-00 Civics
http://honda-tech.com/showthread.php?t=2552431
Unfortunately I haven't seen enough of these parts without their attached cars to recognize differences and similarities. Can anybody recommend a model I should be looking for as a donor? I assume I should be looking at early CR-Vs, no?
Filtering the recirc. air would be relatively easy, just slap a filter on the inlet behind the glovebox.
Come up here and study on some disassembled wagons, maybe you'll get an idea. Maybe we could filter the fan outlet instead of inlet?
ETA: the 5th and 6th gen box puts the filter after the blower and either just before or just after the evaporator.
That's what she said :twisted:
In all seriousness, I really like this idea! And look forward to what you guys come up with!
Bam following u @ WagoPalooza 2010 was pretty dusty ....
the fresh air vent on the driver side dash by the door has its own inlet in the cowl, that would necessitate a separate filter unless it always remained closed;
putting on a filter on the recirculate vent does look easy;
I have these air filter pads that are designed to go over just regular central air vents (in a house) from Home Depot, they seem like a good material (I cut them up to use as air filter inserts for the tower case for my garage PC);
the fresh air inlet for the main ventilation system is directly above the blower housing (in the pass. side cowl) and opens directly into it (which is probably why my blower is filled with all kinds of "outside" debris!)
The only 2 solutions I have come up with so far are: 1. roll up a wad of filter material (like mentioned above) and stuff it into the opening from the cowl side (probably reducing flow) 2. using a big rubber band to stretch a piece of filter fabric over the opening in the cowl. I imagine using this stuff Sears sells which are sleeve designed to go over a shop vac filter to provide additional filtration.
Ideally, a real cabin filter (like for another civic or whatever), could be installed between the blower housing and the vent in the cowl...
The evap case looks very straight, I'd imagine it wouldn't be too hard to modify the case to fit into the wagon. Actually doing it is a whole 'nuther story.
Otherwise, you could use the stuff wes was talking about, perhaps stick some filter element between the blower and evap cases?
Found what? But anyway, the CR-V parts are what those guys (& girls) were using on H-T. I just took my evaporator out so now the flow path is reduced to the size of the duct (non-AC) that attaches to the blower in it's place. I'm guessing that Honda didn't put these kinds of filters in the non-AC cars, but I haven't researched that. It does open up more room for experimentation though.
