Your wagon requires 91 octane gas
 wes wagon
                Band Wagon
wes wagon
                Band Wagon
                    Ha!  I knew I could make you look!  I was checking out the specs section of my factory shop manual for the '89 wagon the other day when I saw something I've never noticed before... it's says the required fuel octane is 91!!!  This is right next to where it says the compression ratio is 9.2:1 (9.1:1 4wd).
Of course, the owner's manual suggests a mere 87 octane. Maybe this is why the shop manual I have is a "first edition" - because they needed a second edition to fix the typos in the first!
Yep, it does.
I'll check to see if there was any more specification - there might be in the owner's manual, but in the service manual it definitely said 91, and I don't think it gave the method.
RON is "research octane" if I recall correctly, which is determined by actually burning the fuel in the lab. I'm not familiar with AKI, I'll have to do a little octane research of my own!
