Leaky door
Hey Guys,
I installed a new passenger door that I got at a salvage yard. The door was in good condition, the whether stripping was still good. But after the install there is lotsa wind noise, from a gap between the door and the car. Now there is no way to make the door close tighter, any tips or ideas to try?
thx
  • 503Wagon503Wagon moderator
    there are several ways to make the door close tighter....
    first you can adjust the latch in or out to make it close tighter. also adjust where the hinges are.
  • speedstar808speedstar808 Band Wagon
    Thx I'll give the latch a try, but the hinges bolt directly to the frame so there is not way to adjust that area...??
    im sorry i should have been more clear, where the hinge bolts to the door. try adjusting there too
