Psud3ity's Boosted BB6
Figured in the pursuit of achieving my 20 posts before I can search for a new rear door for my wagovan, I'll share what's up with my Prelude.
**********************Currently************************
Engine:
H22A from Hmotorsonline (Thanks Steve)
NGK Blue HE65 Plug Wires
NGK BK7RE Plugs
Bosch Cap & Rotor
ImportRP Manual Tensioner Conversion
Innovative 75A Mounts
B&R Fittings Catch Can (-10AN SS lines)
AC Delete
Transmission:
5 Speed Swapped!
M2B4 Trans (Thanks Steve @ Hmotorsonline)
Competition Clutch Stage 4
ASAP Hydraulics Custom Stainless Steel Clutch Line (3000psi rated)
Beck Arnley Master & Slave Cylinders
Cooling:
Glowshift Oil Cooler Plate
Flex-a-Lite Oil Cooler
Mizu Radiator w/ Fan shroud (Thanks Sparkplugs.com)
Turbo:
Lovefab EQ Manifold (44mm Vband Wastegate, T3/T4)
Garrett T3/T4E 50 Trim .63 A/R
Tial MV-R 44mm Wastegate
Tial Q BOV
Fast-Turbo Oil Feed Line & 10AN Return Line
2.5" CX Racing charge Piping
Mishimoto Black Z-Line Intercooler
Exhaust:
Vibrant Streetpower Flat Black Muffler (3"in 3"out)
Vibrant Ultra Quiet Resonator (3")
Kteller 3" Stainless Steel Piping Kit
3" Custom Downpipe (No cat)
Intake/Intake Manifold:
Double Stacked IAB spacers
S2000 Throttle Body
Vibrant Silicone vacuum lines
Vibrant Vacuum Manifold
Suspension/Wheels:
Ground Control Coilover Sleeves
Tokico Blue Shocks
Energy Suspension Bushings (Coming soon)
Innovative Competition Bar
Konig Lace 17x8 +35
215/40/R17 Continental Tires
Engine Management/Monitoring:
Hondata S300 Tuned by Jeff Evans @ Evans Tuning
Hondata Boost Control Solenoid
Innovate LC-1 Wideband
Innovative Auto Timer w/ Wideband and Voltmeter
Glowshift Boost Gauge
Glowshift Oil Pressure Gauge
Exterior:
20% Tint all around
Weathertech Wind Deflectors
Anzo CFCL Angel Eyes
5k H3 Hid Kit
Ebay Black Turn Signals
Ebay Black Sidemarkers
Cleared Tails
WWRS Front Lip (Thanks Toxxic)
WWRS Sides
Audio/ICE:
No Name Touch Screen Head unit (Double DIN) ** REPLACE ME!!! **
AudioControl 2XS Active Crossover Network
CDT CL-6 Midbass
CDT HD-100 Tweeters
JBL P1222 Subwoofer
Rockford Fosgate P300.2 (Midbass)
Rockford Fosgate P300.2 (Tweeters)
Rockford Fosgate T1000 (Sub)
Custom Subwoofer Enclosure & Amp Rack
0/1 Gauge Wiring throughout
Kinetik KHC-1800
140dB on a meter
I bought the car back in May of 2008 with ~65,000 miles on it from Lehigh Valley Honda. 2000 Honda Prelude, automatic:
A week or two later I managed to clip a deer on route 80 with it. Barley dented in the front fender, but enough to distroy one of my headlights, so I ended up picking up a set of CFCL angel eyes from the fleabay:
Installed an AEM V2, and an Apexi WS2 exhaust next...
Then Tint!
The stereo system I'll briefly mention, I don't have too many pictures, but the general layout at this point is this:
Farenheit garbage 5.8" Touch screen dvd player
Audiocontrol 2xs Active Crossover Network
Rockford Fosgate T1000-1bd (Subwoofer)
CDT HD100 Tweeters / Morel MDT 12 Tweeters (I switch between them, havent decided which I like better)
CDT CL-6 Midbass
JBL P1222 Subwoofer
Total RMS is around 2500w, About 140dB on the meter.
So, ran into a snowstorm one day, and the dreaded SS auto transmission failure reared it's head. SO I decided to fix it:
Don't laugh, this transmission was $80 and lasted 2 years
5 speed swap done
Bought some rims! 17x8 + 35 Konig Lace
About a year later, I started to loose 5th gear on the transmission, and then the crank pulley bolt walked it's way out. I fixed it, but the keyway on the crank was damaged, and I started burning ALOT of oil. I started getting ready to swap in an h22a, and change every seal possible on the motor. Picked up ground control coilovers and tokico shocks as well.
I ended up calling steve @ hmotorsonline, and I couldn't be happier with what he sent me:
Hmotorsonline FTW. You could eat off the thing: ** i'll edit and reorder these later so they make sense**
So, 5th gear grind fixed, motor has excellent compression, runs like a watch...
That's enough for this post. I'll reply to reserve the next two posts for the rest of this, but I'm sure my boss would appreciate me doing actual work instead of rehashing my build thread.
  • psud3itypsud3ity New Wagonist
    And there's more!
    After the swap, I was offered a free Mizu Radiator from a vendor on the prelude forum I'm on:
    Badass radiator. Fans are incredible. There's literally a breeze in front of the car when they come on.
    Someone backed into me and thier insurance company decided to buy me a brand new VIS CF hood:
    Since the car was mechanically sound, I started work on making it pretty, starting with a WWRS Front Lip and Side Skirts:
    So then I got to thinking... I've got an h22a with 210,210,210,210 compression, and more parts started arriving:
    Tial Q BOV
    Walbro 255LPH
    Mishimoto Z-Line Intercooler
    New battery for the system:
    Tial MV-R Wastegate, this is pictured on my old Mini Me manifold, which I sold to go with the Mini Me EQ from lovefab
    Exhaust parts started coming in... Vibrant Streetpower muffler, Ultra Quiet Resonator, 3"
    Precision 880cc Injectors, low impedance
    Innovate LC-1
    Fast-Turbo Oil feed/Return Lines:
    Ebay IC piping kit:
    Kteller 3" Piping kit:
    SNAIL!
    So now, Just had to put it all together. We started with the 3" exhaust and changing the clutch, hooking it up as a cat back until I could get the rest of things together:
    This will present a problem in the future...
    Here's a clip of the exhaust:
    http://www.youtube.com/watch?v=hIMvdpgRlRg
    Threw the fuel pump in as well, not too much exciting stuff there, just a fuel pump.
    Got my hondata s300, and my B&R fittings catch can setup as well.
    [img][/img]http://i573.photobucket.com/albums/ss18 ... G_0727.jpg
    Once the exhaust was in, the manifold finally showed up:
    Some other random parts, IAB gaskets, silicone vaccum hose, turbo timer with wideband display... yada yada yada...
    Started mounting the intercooler:
    Had to ditch AC sooner or later:
    Then, I got the email from lovefab that my manifold was done...
    And then it showed up!
    Decided to test fit the manifold, and of course, lovefab half assed the thing. Mounting holes didn't line up, had to sit there with a die grinder and fix it. Along with a bunch of slag left in the manifold. For a $600 manifold, the thing should have been spotless. Won't be buying a thing from them ever again. Either way, got the manifold installed with the turbo and everything, and immediately noticed a problem.
    No way I can keep that front crossmember. Thankfully, Innovative was nice enough to get me a traction bar made. Had to reschedule a tune, but oh well.
    Installed the catch can...
    And properly mounted it. Goodbye EVAP system.
    Had the alternator go out on me randomly. Guess the 2400w RMS finally cooked that little sucker. High output will happen down the road:
    Had some motor mount issues too... Especially without a front mount I wanted to beef them up. 75a bushings
    Then, I went home to get the car ready... starting with that front crossmember.
    So that's done, time to start the plumbing.
    My buddy Ray and his trusty angle grinder:
    Some other random pics of final assembly, I don't like how close the oil feed sits to the manifold, so I ordered a 45 degree fitting.
    3" downpipe completed:
    Blurry pic of my oil return line:
    Welding on the intercooler piping, all TIG, done by a friend with 40+ years behind the shield. He's truley a master at what he does:
    Unfortunatley, this is where the thread ends for the moment.
    I was missing a 90 degree silicone coupler for the charge piping leading to the intercooler, combined with the oil fitting issue, and not having a 15 degree bend for the screamer pipe to clear the slave cylinder, I had to leave the car at my parents house until I can get those parts.
    Oh wait, they're here. As of today, 4/26/12
    Power goal is 350hp, and it will be at evans tuning on my birthday, may 8th, to finish the build.
    Not really a fan of the headlights but everything else looks nice... Welcome to HCW
    Yeah, not everyone likes em. Which is fine, because it's not everyone's car. It's mine.
    To each thier own as I always say, but I'm excited to have another honda to toy around with. I hope my wagon comes out half as good as the prelude and I think i'll be alright.
  • Nice WORK!
    Okiewagon1 wrote:
    Nice WORK!
    Thanks man, I appreciate it. It's been countless hours, weeks, months, and years getting the car to this point.
    Hopefully it hits my power goal on the dyno, or at least close.
  • I recognize this stud of a car. This Prelude/Wagon thing is awesome. :lol:
    Figure a small update is in order.
    In 7 days, I'll be back to working on the lude, and it hits the dyno on may 8th. Hopefully I don't run into any more snags.
    Only concern I have is the fuel injectors properly sealing on the IM. I primed the fuel pump and it seemed fine, but I won't know anything until I actually try to start the car on a basemap and see if fuel is spraying anywhere out of the IM.
    Some more engine bay shots:
    The dyno video:
    The graph
    325hp, 230ft-lbs, and 9.8psi
    Car is a friggin blast to drive.
