Thanks for the props guys! I decided on the silver after seeing NJ's wagon,that thing is beautiful. For now my 1.5l & AT is stock and sluggish,but I would like to swap a MPFI engine in it when i attempt the drivetrain swap. After looking through the susp. section I decided on some ef hatch springs with my wagon stuts. As for my wheels I chose 17x7 up front & 18x7.5 in tha rear. I tinted it myself with some 5%. I also did the body work & painted it. I want to put a lip on it but I am undecided about witch one to put on.
just to let you know, you wont be able to run those wheels with the 4wd setup unless you can find tires in both sizes that are exactly the same outside diameter.
Do a quick search and you will see all the different lips. Accord lip, CRX SI lip (I have on of these), VW lips you have a few different options.
Putting a lip on there will even out the lines a little bit better. I always felt that Honda forgot the lip when you look at stock body wagons. It really looks like it is missing.
Put a lip on there and you will see what I mean.
i couldn't agree more. it just looks like somethings missing. i'm rocking a vw mk3 lip. look for my thread under member rides to see pics of how it looks
That doesn't quite work. You need hatch/crx/sedan struts in the rear if you want to use hacth/crx/sedan springs. Otherwise, the back gets lowered lots more than the front. You see, rear wagon struts have a lower spring perch than all the other civic models. Coilovers could work with your wagon struts, but even at the highest setting, the rear will be dropped quite a bit. No biggie, just drop the front to even it out.
That stance looks good, or is it the wheels, look like 17's from here? Either way, pretty dope.
Nice WAGON!!!!!!
is that a 4-sqaure snowboard sticker on the back window; if so
extra pionts for you....
Nice wagon, BTW. Welcome to the site.
