High Output Alternator?
 1Fastboy
                New Wagonist
1Fastboy
                New Wagonist
                    Did some searching and only found a handful of posts. Question is what have you done to to upgrade your electrical supply? If your like me your taxing the heck out of that little thing under the hood and your system is starving for amps and you don't care because the bass is pounding and your HID's are burning bright.
Anyone running a aftermarket HIGH OUTPUT ALT? I found 1 source so far that offers the "best" but at a cost. DC power engineering has an HP series for a 92' civic that runs 180 amps. Now for my 89' wag I haven't called them up yet but to my knowledge the only difference is in the pulley for the 2 years mentioned, mounting points should be the same....
Any one have some ideas on fitment years/compatibility or a competitive High output options for alts?
Do both.
You should have seen how weak that car was before the alternator I put in it. That Optima is stupid nice to have too though.
I know that running a second battery on a battery isolator is a wise choice. like most 4x4 enthusiasm they run a second battery and upgrade their alternator to make up for the demands. winch,floods, etc..
any ideas on how to calculate?
as for me I plan to run a second battery (2 yellow tops or comparable),isolator and high output alt.
it sucked idling honestly and it wailed like a banshee till i got a smaller belt put on (the pulley is tiny.) but it kept up with all the draw i was pulling just fine. price wasnt bad either
http://storesense1.mysuperpageshosting. ... bok?no=774
Like you said it sucked at idle.."The original alternator has only 65 amp capability.
The Load Boss Performance Alternator Provides:
Output Rated @ 70-75 amps at 800-1000 rpm and 170 amps at 1800-2000 rpm. "
Option 1, expensive looks well made and has allot of promise. lots of info.
https://www.dcpowerinc.com
Option 2, close to half the price, custom made to order not as much info as DCpower.
http://www.vitalpowercells.com/
A high output/amp alternator should be the first upgrade made to your electrical system anytime you increase the electrical demand on your car. Failing to do so will eventually cause damage to some if not all of your electrical components. Also something else that most people don't even think about is the ignition system. Your ignition system takes a good amount of power. Once you start adding stuff like audio amps or extra lights your battery and alternator will struggle to provide enough output for everything. The ignition system will become starved resulting in a weaker spark which translates into decreased engine performance.
When you upgrade the alternator it is highly recommended that you also increase the size of the main power distribution cables and grounding cables so that the power can flow more freely.
Lastly, avoid those cheap rewound alternators if you can. I have used them and while they do work, they do not work as well as they advertise, usually half the advertised rating. Also avoid alternators with smaller pulleys (I think they call them overdrive). The overdrive pulley will wear out the alternator much more quickly and there is also a increased risk of causing damage to your electrical systems due to high voltage over charging. Remember, you want high amps, not high voltage.
DCPower is local to me and while I have never used one of their alternators one of the top audio shops in the world who I have worked with before "The Audio Shoppe" uses them all the time.
any updates?
Indeed! it finally came in..
Billet aluminum with huge cut outs for cooling, Black anodized and engraved pulley. NICE!*****
Plug in a slightly different location. ( makes more sense I think)
A bit more copper used it out weighs the OEM unit by about 2 Lbs.
Comparison to a OEM B18 Alt. Its a bit smaller in width so I'm curious as to if its going to be necessary to notch the frame when I drop in with the B18.
Its a bit smaller in length so I'm curious as to if its going to be necessary to notch the frame when i drop in the B18.
Thank alt. looks BA by the way.
