hey whats up everyone been just using my wagon for a comuter so didnt have time to work on it I finally just took it apart and re did my engine bay fresh paint and wire tuck bought a Del Sol today so I can keep working on the WAGON through the winter and be done by spring Ill keep you guys updated
Xs power battery traction bar and already have a halve radiator and have always wanted air ride so thats a must for me.... interior just need to replace seat cover on drivers side everything else has been changed for better oem stuff
after cleaning the bay I forgot to take a before picture
before unmasking
masking to prevent scratchin the bay lol
AC delete plug added
and the new comuter bone stock with wheels and cold cold AC and faded carbon fiber hood
Wow.. I love that motor.. I just put a d16y8 in my wagon.. It runs like alittle go-kart... HAHA.. I also got a cr-x to match black and white 91's.. Keeep it up.. Its looking good..
was going to wait tiil I was done but I couldnt. I modified my cross member so I can fit a half radiator
relive cuts had to push it back an inch
finished but waiting on my radiator to show up so I can weld brakets
Here a little more progress on my cross member little more trimming then anticipated had to cut another half inch off
sitting on stock radiator mount
after I cut mounts and half inch more of the front
and Hood close, painting tomorrow and finishing welding I'll post more pics
Here it is, it was a lot work. when I got my radiator I found out it needed more cutting but its done now
here it is installed just need to move brackets 1/4 inch
Just found some prime 5 spoke wheels getting them for 75 with tires not fittipaldi wheels like I always wanted but close enough they come with all center caps
Fabricated a breather box going to weld it up when I get time this week
MOROSO filter and some tape to hold it together for now
Now on the wagon tomorrow I'll build bracket to bolt it on firewall
Trying hard to make it look good I have a friend that works at a Honda dealer and want to store it next winter on their show floor the only problem I can't decide if I should use 6an or 8an fittings already have 20 feet of 6an hose but it looks small
I love the wheels too my EK came with a set when I bought it back in 2001 and regret getting rid of them got this set by pure luck I want to Polish them to look like yours. Did you buy them like that or did you Polish them
I was at the junk yard today and like always I go by every row to see what I find and today I found a Suzuki Swift spoiler fits pretty good on the Wagon
pow mow now
and my old wagon now joshi918's wagon
before unmasking
That may be the coolest add-on cupholder I've seen! Is it bolted to the body/floor?
Good work and looks clean
next time I do a swap for sure I'll shave it and brake line tuck
Love those B series motors!
And great job on your CRX and love your Wagon
Before
after
In the light
