M/T Swap Wiring...?
 90 RT4WD (Cody)
                Senior Wagonist
90 RT4WD (Cody)
                Senior Wagonist
                    Hey, Yes i am new to this forum. i did a manual swap in my 1990 RT Wagon, i have a couple of questions, and was hoping to get them answered. thanks in advance!
First: what ECU should i use? i have the stock d16a6, and Second: what about the wiring, like reverse lights, and the auto neutral saftry witch? :oops:
For the record, i am driving the car every day, it just runs bit funky. but i also need a few others things too...
You should use a Manual ECU.
Dont know about the rest sorry
The reverse light switch on the tranny has 2 wires (yellow and green). Those need to be extended into the car where your old auto shifter was and plugged/spliced in there. I don't know which wires off the top of my head. You don't have to worry about the clutch safety switch too much, but you will need to rewire the park switch so the car always thinks it's in park or you won't be able to remove the key. Sounds like you might have this part already though.
As mentioned I need one for the mpfi swap!
you need a PM6 ECU
Think I might have found a distributor that will work just need to get the ecu worked out.
Don't really have a way to test it if I do buy one though might have to get one of you guys to go with me so I can make sure it is in working order when I find one!
Or if buy one from online have someone swap it into their car so can make sure it works!
http://wikitest.pgmfi.org/twiki/bin/vie ... NYHARDWARE
