Rt4wd gas tank dent how can i pop it?
 klum
                Senior Wagonist
klum
                Senior Wagonist
                    As some of you know the rt gas tank has a access panel thru the seats which makes it easy to do fuel pumps on it. im curious if i have a dent in my gas tank
1. Will that cause my fuel to cut out when cornering only left turns
2.can i pop the dent out using a rubber mallet and rubber chizel without risk of detonating the gas?
I had a friend almost kill him self recently because he was sawing at a gas tank that he thought was empty and had some water in it still so im a little nervous to jump onto fixing this situation.
Did your friend's experience lead to fire? I once lay under the back of my Wagon with my angle grinder to cut an exhaust bolt at the area where the flange is just above the rear LCA. Once the head of the bolt fell off, and after substantial grinder sparks, I was greeted by a stream of gasoline coming from the cut I had just accidentally made in the corner of the gas tank. No fire. Just a big mess of gas on the floor and carpet I was laying on under the back of the car.
How big is the dent?
The fuel pump pickup generally sits in a pocket, so unless that is the area that got crushed I don't see it causing an issue on turns.
Remember gasoline vapour is more flamable than the liquid.
Be careful and you'll be fine.
