Multiple cluster issues.
Hey guys, my cluster has been acting up recently and it'd be nice to fix it. Any input is welcomed. So first off, I'm throwing a code 17 for my VSS, this would explain my speedo and odometers not working. But my heat gauge will say I'm off the charts and then in a split second it'll say it's cold like I just started the car. The car isn't changing heat that fast, so why is the gauge reading like this? My fuel needle never goes to full when I fill my car up, only about 3/4 of the way, and my tach will read that I'm turning 9k rpms when in reality I may only be hitting 5-6k rpms and this only happens when I hit WOT. Any ideas? It seems like there will be a few different routes to fix this, but in the end I'd like to continue using my original cluster. Thanks fellas.
viewtopic.php?f=10&t=14697
