Interior fan not woking (89)
It's just that. All other interior electricals work. The interior fan WAS working untill I had "Crappy Tire" replace my radiator and my AC/altenator belts. Now my interior fan is dead. I've checked all the fuses and everything SEEMS to be in order there. I have no idea where any of the wireing for the fan is located and I'm thinking perhaps something got disconnected or bumped when they did the rad/belts. Any ideas?
take out the glove box, then look in the new open space you will see the resistor you cant miss it it has 2 phillips screws holding it in and a plug to it. its an old car they will fail. common symptom is the fan only works on speed 1&2 or 3&4 but sometimes they all together go out.
rockauto has the resistor for 25$ new. or salvage yard but then your buying another old one.
I feel your pain but thats the best advise
I hate when i say they fail heres the scoop---- "its a resistor that has coiled wire with ceramic over it, the resistor becomes brittle and breaks causing a fan speed not to work, sometimes they both break = fan no go." good luck !
keep us posted
the power supply you would be checking from above, if not mistaken is the plug to this resistor.
You are correct!!
