Car RUNS but NO GO.. Fuel fump reads empty..
 cstanya88
                New Wagonist
cstanya88
                New Wagonist
                    Okay I am in a bind.. I just got a d16y8 swap in my 91 wagon.. When I turn my car on, my fuel pump gauge just dies.. Car runs and all but wont go.. What could the issue be.. Somebody said I had a kill switch But have no idea.. Before I start the car no check light.. Ill start it check light goes on.. Turn on the lights or press on the brakes and the car wants to stall.. Corner lights are on when the switch is off.. I got a brand new main relay so No clue.. It was running well yesterday. But then i saw my gauge start cutting off. Then go back up then run like a champ all day..
fuel gauge,stall,corner lites,press brakes(dash lites up or stalls) & shakey idle.
You know what it might be.???Loose battery terminal and electrical shorts.
i went though a looong drawn out process with that exact same symptom... sort of. my car wouldnt fire at all. but only got 10v on fuel pump.
never figured it out so i soldered 2 contacts inside the relay so it bypasses the actual relay. but after looking back at my post on here im almost sure its the ignition switch. bam even suggested it... when will i learn to just do what he says lol. ive had to replace the switch since then. i should take the solder off my relay to test my theory.
