'91 wagon charging/electrical issues.....
My '91 civic wagon will start up and charge the NEW battery that has NEW battery cables. It has a new Alternator.
When I turn my lights on the dash instruments wig out and the car tries to die. I have checked with known good ECU's under dash fuse box (ELD) known good batteries and alternators ......anyone have any other ideas?
you should have one from the battery to the unibody which then connects to the transmission.
you should have one from the valve cover to the rad support
and last and the most important, check the ground for the ECU which is attached to the engine block @ the thermostat.
1)headlites
2)dash lites only
are you 100% sure you checked the thermostat ground?
1)Turn on headlite.Does dash wig out?
2)If not.
3)Turn off hdlite.
4)Plug in fuse 4.
5)Repeat steps 1-3,but in step 4 add a different fuse from above list.
:shock: When the dash does wig out .The short or prob is in that leg of the line.
LOL(lucks of luck).
