Is this a common AC problem? leaks in the pass floor...
is this common for wagons? have anyone had simliar problems with fluid leaking into the passenger side floor?
anyone know how to fix it?
the water that's coming in is ice cold i guess from the ac condenser and evaporator under the passenger side. so it's water from the outside??? like when we washed the car or it gets rained on???
i'm confused becuase it's not raining when it drips.
thx for the reply, a bit more info could help me, i'll be doing a search to see if i can find info on it.
oups, thx for the welcome and help
I'm a bad admin :oops:
you most likley have a spider web in the tube or debris as someone else has said. this works every time.
