b series plug help(updated with actual pics-7-18-2011)
ok guys so i finally got a swap in the wagon. type r head with crower internals. high comp pistons, b18b block. i got everything switched from my 91 si hatch to my wagon. my problem lies in one last plug i hope. its the plug behind the drivers shock tower. its tan and round.the plug on the b serriees harness isto big or too small to plug into the one on the car.
looks like the one on the left.
my problem is is the plug coming from the wagon is i think i counted 11 wires. and the plug thats supposed to plug into it from the b series harness is i think i counted 8 wires. i follwed the plug inside the car and it gots into the cabin harness. if it had a plug inside the car i was gonna just unplug it from the hatch and plug it in the wagon.
i drove the hatch and everything was plugged in and working.
i wasnt sure if they made a jumper for the 2 or if you guys just cut and rewired something.i figured before i counted the different numbr of wires i could cut and splice in th new connector but id have extra wires.
please help me this is one of the last things i need to figure out to have the wagon onthe road. i also was thinkin that the plug was fo the injectors but im not 100% on that.
these are the actual plugs im having troube with.
this is the driver shock tower plug on the wagon. its a round connector with 12 wires.
this is the same plug but in the 91 civic si hatch. which the b swap was in. it is a round plug with 8 wires.
this is the plug on the harness that is also round 8 wire that needs to plug into the shock tower plug.
i kno that the eight wire plug is for the injectors. i color matched the wires in the plug with the injectors. all colors and amount of wires match.
so i need to know if i have to make a jumper plug between the 2 and or what each of the 12 wires go to! i figure that the reason the plugs wont match up is because the wagon was dual point and the hatch is multipoint.
with that said im not sure if kahuna(whos wagon this was)had a jumper plug wired at one time. because if any body remembers he had a b16 in the same wagon.
if anyone can tell me what the 12 wires go to and how to make a jumper plug or maybe just point me in the rite direction i would gladly appreciate it.
thanks fr the help in advance.
looks like the one on the left.my problem is is the plug coming from the wagon is i think i counted 11 wires. and the plug thats supposed to plug into it from the b series harness is i think i counted 8 wires. i follwed the plug inside the car and it gots into the cabin harness. if it had a plug inside the car i was gonna just unplug it from the hatch and plug it in the wagon.
this is the plug on the harness that is also round 8 wire that needs to plug into the shock tower plug.i kno that the eight wire plug is for the injectors. i color matched the wires in the plug with the injectors. all colors and amount of wires match.
edit: Upon reading more closely, you said it'slikethat plug. What year is your wagon? I recently ran into a similar problem with my '89.
Read through this and see if it helps.
viewtopic.php?f=10&t=8546&hilit=%2789+wiring
my wagon is a 91.yeah it looks identical to the one on the left. i dont think that wll help. both plugs are round not square. i looked at all the wire colors and each injector has the same color wire thats in the plug. for example.
1 injector has red/yellow
1 injector has light blue/yellow
1 injector has brown/yellow
1 injector has i think dark blue/yellow
i cant remember the last one due to not having the car in front of me.
the plug has one wire of each of thos colors and i think 2 yelllows or just one.
i have a d series harness that is dual point and i grabed it to see if the plug off that plugged into the shock tower plug and it does. the d series harness came with the wagon.
all these wagons with b swaps and no help?
come on guys i need to get ths n the road.
If the 8 plug wire is too small than just convert the stock harness to mpfi and obd1. It's easy, there are plenty of write ups on the interwebz to do it. I have seen that some harness' have smaller shock tower plugs than others.
As charb and another friend told me, rule of thumb: Always use the standard harness for a swap.
It's less of a headache.
Take it from me, i've done loads of DPFI conversions and B-series ED/EE chassis swaps. Using the original harness will save you a lot of headaches and wire tracing.
also wasnt sure if i could make a jumper plug to go from the shock tower plug to the enngine harness.
also the swap is obd1.
The Si was a factory MPFI car, the Wagon (unless it's an RT4WD) is a DPFI car and will need to be converted to multi-point. Even if the wagon had a B16 at one point, it's still not a factory MPFI car. Both the car side and engine harnesses are different between the MPFI and DPFI cars. You can't use the MPFI harness (from the 91 Si) in the wagon, the plugs and plug pin-outs don't match at all.
Unless you're out of options i'd rule out the jumper plug option, it would be more trouble than it's worth. I'd use the engine harness that came with the wagon(if you have it) or see if you can acquire another DPFI harness(wagon, hatch, 4-door) and convert it to MPFI. If you're running an OBD-1 engine and plan on running and OBD-1 ECU, you can convert the distributor plugs, eliminate the need for a resistor box, and do the other minor OBD-1 provisions when you do the DPFI conversion.
viewtopic.php?f=7&t=11851
