my new awd build yay!
Well heres my newest wago bought this about 2 weeks ago. orginal montana car. so no factory ac. but came with some new bridgestone blizzaks for winter.
right after i got it home. has some rust on rear qtr otherwise pretty good shape.
Pulled this off my wrecked awd that i traded a auto wagon for.
rear end gone and pic of the cancer
rear end installed and diff bolted up. had to drill throught body and use some licking nuts and washers worked out great.
Shifter box installed along with cables
went ahead and pulled everything. was gonna leave dpfi. but i had a z6 laying around.
z6 setting in. still got driveshaft to mount and tranny to install.
more pics to come working on wiring tomorrow along with bolting up the tranny. then making some brackets or something for the coupler. if ayone has pics of this installed on non awd wagon that be would great to see how you all did it. thanks looking.
    Awesome!
    Keep us updated
    still wish i had my grey FWD auto wagon. wanted to do the same swap but got an offer i couldnt turn down. post pics of the driveline mount that ya make that was always my concern with mine.
    nice progress!
  • tonytonestonytones Band Wagon
    can't wait to see the new build, Freek. I read that other post about the unfortunate mishaps of your previous wagon.. =(
    Still going strong though. I can appreciate that. Keep up the great work man.
    looks like a fun project except for the rust.
  • FreekFreek Wagonist
    which are talking about. i just sold my ls wagon. i traded a auto dx for my wrecked awd that pulled everything from lol
    ok just read some stuff that might cause me some problems. i didnt realize that the awd's have a intermediate shaft. i do not have one so will my reg dx axles work til i get an intermediate shaft? which one can i use?
  • 3rd4ce3rd4ce Council Member
    that shaft should of been on the back of the donor RT trans....
    motor was gone out of mine. id say they sold it with the motor
    That stinks.... :cry:
    :idea: but lets c if there is a loose one floating around .... this is a swap 4 real..
  • ReaccionReaccion Senior Wagonist
    Nice, just like mine when I first bought it...
  • flipside1212flipside1212 Band Wagon
    looking good, keep it up man
    Anyone else have a thread doing the same thing?
    motor and trans installed just got finish up wiring tomorrow. then axles and maybe start on the driveshaft
    question need to no asap i used my 90 2wd clutch and flywheel on my z6 awd. my starter will not fit right any info on why this is?????????
    i thought d-series staters were the same from 88-00....
    ithought so to but i guess not cause it will not fit
  • mgcookmgcook Band Wagon
    I believe you have to use the starter that is matched with the tranny, not the engine.
    update: i had to use a newer starter the old dx one would not clear for some reason. threw one on from a 95 dx worked perfect.
    as of now everything is mounted up axles in. got the intermediate from arkansas. still have driveshaft to mount.still have to run vtec. do i have use a 4 wire o2? trying to find a good diagram for wiring vtec but haventseen one yet.
  • update: been busy with my new job. getting this aligned tomorrow then tuned in a few weeks. heres a under shot with the exhaust. not much room for exhaust. gonna be checking out to see how much for one piece driveshaft at local fab shop also.
    have a problem. car cuts out when i remotely get on it. stalls have to let off gas then press again? any ideas. ive replaced vtec solenoid dizzy got check iacv...
  • realtimefunrealtimefun Senior Wagonist
    sounds liek you have a sensor crossed or broken maybe tps or map
    Well little update going along with the master scrappy lol. Picked up the accord and da suspect yesterday along with the rear sway for install this week sometime
    nice... hope to see more pics and progress...
    K update rear almost done some adjusting and aligning. Front disassembled will resume tomorrow. Pics
    Some eye candy while working
    Rear lifted
    pffft master scrappy who copied the real genius....ME.
    wagon is coming along nicely, looking forward to photos of it being lifted!
    Thanks your input is much appreciated
  • what are you planning on doing for tires?
    No clue yet gonna run on my 13s with blizzaks for now til I find something
  • im running 205/60/15's and i dont rub anywhere....im going to pick up some 215/65/15 winterforce tires and see how they are with out any modifications to the chassis.
  • ami wrong or are your speaker pods installed backwards?
