Dpfi to Mpfi, Cel 4
I need some help from someone here with experience doing DPFI to MPFI. My car is using the stock DX harness with all of the Z6 plugs added where necessary. Ecu is a PM6. Dist is a brand new unit.
I pulled all of the old gear out of my car, did all of the wiring according to http://www.fourthgenhatch.com/mpfi.html
She starts up and runs fine, firing on all 4 and such. I'm getting CEL #4 though. I've gone back through all of the Distributor to ecu wiring, soldered everything, put the appropriate plugs in, etc. Measured the ohms on the Crank angle at the dist, checks out in good spec.
Anyone have a running MPFI swap and know off the top of their head which pins the crank angle goes to? The guides say B10 and B12 on some sites, Other guys are saying its B15 and B16, my Chiltons book for EFs and Del Sols says B15 and B16. There is just a lot of conflicting information regarding it.
Any help is much appreciated, I'm hoping someone here can provide some insight before I mess something up.
Always something. started up and ran before I fixed the crank angle problem. No codes. Back to wiring. :roll:
check and recheck the pins! then recheck again :P they are tricky little bustards.
The crank angle sensor seems to be reporting out of spec at my ECU. What I've read says it should read between 350-550 ohms, mine is reporting between 280-380 to the ECU. Anyone with a little more knowledge of wiring than me know what would cause a drop in Ohms between two points?
this link looks solid as did your link, check it out you may have something backwards.
http://hondaswap.com/civic-crx-ew/dpfi-mpfi-92385/
The proper resistor with injectors to match.
The wiring is correct DOHC vs SOHC
the c1 to b10 pin, c2 to b12 pin
new C1 to dizzy blue/green stripe.
new C2 to dizzy blue/yellow stripe.
Good luck keep us updated.
//edit: Oh yeah, a source. Read http://www.honda-tech.com/showthread.php?t=2889205 to learn that apparently injector power comes from A15.
Heres a video showing exactly what I'm talking about as well.
http://www.youtube.com/watch?v=7l7XaeYZzQc
